- Nov 29, 2014
- 24,995
It's not that a 110v isn't good/strong enough, it's just limited to thinner material. It would be a good a good unit to learn on, if your garage isn't wired for 240v then it's hard to justify the investment.
Welding is a high energy application.
It gobbles up AMPS
so a 110V unit will gobble up a bit more than 2 times the amps of a 240V welder which gobbles up more amps than a 3 phase welder.
The thicker the material, the more power needed so the more amps required but you are limited as to how many amps you can pull through a domestic power outlet.
The wires get hot which increases their resistance which eats up yet more amps.
Thus the lower capacity of 110V units.
Also remember the earth connection to the metal must be good and clean as well.
Another reason why I like gas welding.
Filthy metal covered with paint / rust/ grease/ grass, etc no problems they just burn off.
