10323 governor
fdsinozich
Put on new governor spring and rpm adjustment is fine. Get in high grass and it bogs instead of stabilizing rpms.
What's up? Thanks, Frank.
Hi Frank,
I tried taking a picture of my 10323 Lawn-Boy, but my camera doesn't take close ups well. So I'll try via text,,,the long part of the J bend on the governor spring needs to feed through the square hole on the governor. Also make sure to clean the carb and make sure the governor shaft rotates freely.
Regards
Jeff
