Mini Motors
- May 11, 2011
- 8
- 226
I bought this 2 stroke Ryobi string trimmer w/ electric start in '09. Kinda cool. But I didn't quite get all the fuel out of it last year, and most of you know the drill. But there's a twist.I can't get the carb totally apart. The low and high mix screws are not common screws, and are recessed in a raised up area, so even needle nosed pliers are of no use. As a tool junkie, I've seen plenty of security screws and the tools to match. This is quite simple. The screw is round, with only one small divot on the rim.
Now, I'm not looking for advice on what to do. I've resigned myself to replacing the carb. I've found one fairly cheap online, and considering it a newer superseded part, it may not have the weird screws. Ryobi's comment was that the screws were a result of some EPA B*%$ S@#t, and said they couldn't sell me the tool and my only recourse was an authorized Ryobi dealer. I call B*&l S*&T.
So, my question is has anyone run across this with other brands. I'm trying to figure out if this is real EPA B/S, or Ryobi B/S.
