06 TB Big Red Horse, deck power issues.
molecrusher
Newbie hoping to cash in on the collective wisdom here. My Big Red Horse was running fine when I lost power to the deck. Engine kept running so I drove it into the garage. The 2 year old belt appears to be fine, and the pulleys turn well. After turning the key off, I got no response when trying to restart it. No clicking or anything. A very little bit of research leads me to think it may be the pto power switch( the pull/push type) or hopefully not, the electronic clutch that powers the pto pulley. Can anyone give me some direction ? Is this a common issue with that year tractor? I can turn a wrench fairly well. but do not have a multimeter or testing equipment. Is that something I need before proceeding or replacing parts?
mechanic mark
Yes a multimeter is a valuable tool to have when troubleshooting electrical problems. With key in pocket I would first check ignition switch & PTO switch connections by hand at backside of dash, unplug each one at a time looking for corrosion or rust. You are absolutely correct, locate the problem before replacing parts. I would also look to see if you have an in line fuse blown. I would also check all electrical connections by hand starting with battery. With key in on position do lights come on? If not remove battery & take to auto parts store for load test, this should be of no cost to you. I wear a mask, safety glasses, & neoprene gloves when using cleaner below. Let us know what you find, thanks, Mark
molecrusher
Thank you Mark, I'll use your suggestions this weekend and give an update.
To test for continuity all you need is a globe and 2 pieces of wire
I would have been nearly 30 before I got my first meter although I was know to borrow some gear from the lab.
Funny when you think I was working with an electron microscope by day and fixing my bikes with a transistor battery & speedo globe by night .
