Did they leave the Briggs decals on them?Rural King did the same thing. They would sell engines with the code ground off, which resulted in you purchasing a new engine with no warranty.
Yes. Where the model numbers were stamped into the blower housing it would look like somebody took a dremel tool and ground the code portion of the model, type, code.Did they leave the Briggs decals on them?
Looks OEM except the model/type/date code is missing. I’m very familiar with 3, 5, and 8 HP horizontal Briggs engines.Did they leave the Briggs decals on them?
On Andrew’s the decals are in place. So unlike the Rural King ones, it doesn’t look like Briggs was trying to disassociate themselves from the engine. My guess is that Rural King bought a lot of engines that didn’t pass Briggs final inspection for some reason. Could have been purely cosmetic. So Briggs removed any of their identification so they could be sold at a discount and without warranty. Andrew’s machine was also de-identified, but under a shade tree, and judging by the shiny rectangle framed by dust/dirt, very recently.Yes. Where the model numbers were stamped into the blower housing it would look like somebody took a dremel tool and ground the code portion of the model, type, code.
The Rural KIng ones were overstock from manufacturers that purchased too many engines for their operation, and the excess was sold under the table at a discount, and the code was removed so the engine couldn't be traced back to the original OEM that purchased them..On Andrew’s the decals are in place. So unlike the Rural King ones, it doesn’t look like Briggs was trying to disassociate themselves from the engine. My guess is that Rural King bought a lot of engines that didn’t pass Briggs final inspection for some reason. Could have been purely cosmetic. So Briggs removed any of their identification so they could be sold at a discount and without warranty. Andrew’s machine was also de-identified, but under a shade tree, and judging by the shiny rectangle framed by dust/dirt, very recently.
In most states there is an agency that inspects and regulates retailers to ensure marked prices match the price at the register. Typically it is called Weights and Measures but could have a different name where you live. Often it is in the Department of Agriculture or Consumer Protection. Google your state for the correct agency. Then lodge a complaint if this is a common event. Many stores have rewards for identifying errors. Harris Teeter, the grocery store, will give you the item for free if the price marked doesn’t ring up accurately.Sounds like I need to stop buying things from RK as I don't deal companies like these.
It sorta like a Walmart store I deal with that is cheating their customers on reduced priced items by charging full price at the registers. I have caught onto what they are and do have own way to this thief by register. Most don't ever look at their receipts but I do. They tried to burn me for $20 in the last week as I was buying reduce price produce for my chickens as a treat. The local store has repeatedly told about the problem and they has refused to correct it. Hopefully me contacting corporate via email will get this thief by deception resolved. Sunday will be the tell or not.
