Fair enough fellas, you got me. I was so locked in on the grunt n kickback that I kinda blew right past the fuel side.
@sgkent and
@slomo that makes sense. Even at 145 if its gettin proper fuel it should catch and keep runnin, not die half a sec after the starting fluid burns off. Fuel flow at the inlet and gas in the bowl both checked out, so whatevers starvin it has gotta be past the bowl. Main jet, emulsion tube, somethin in there.
@slomo I hear ya on the ether, its goin in the trash lol. Gonna spray some 2 stroke mix in the carb tonight and see if she keeps runnin while Im feedin it. And yea on the carbon. 10 yrs n 300 hrs and I doubt my neighbor ever had the head off, so its prob caked in there.
Cam kit from fridayparts is delivered and waiting so heres the plan for the weekend. Crack the sump, swap the cam, line up the timing marks and fish out any busted ACR pieces. Pull the head, scrape the carbon and throw a fresh head gasket on. Shroud has to come off for that anyway so Ill clean the fins while Im in there. Then the carb comes back off and gets torn all the way down. Emulsion tube, jets, float height, the works.
Will report back once I get the case open. Appreciate yall callin out my blind spots
