G Gord Baker Well-Known Member Community Leader Joined Aug 21, 2018 Messages 566 Oct 22, 2026 #51 Try using some quick Start. It seems you are over your head in this. Check that the valves are set correctly and that the Flywheel key is in place. Clean Spark plugs.
F Forest#2 Well-Known Member Community Leader Joined Apr 17, 2022 Messages 861 Oct 22, 2026 #52 Old post. seems he is a GHOST.
G Gord Baker Well-Known Member Community Leader Joined Aug 21, 2018 Messages 566 Oct 22, 2026 #53 Scammer
