Hello J.,Hello I have a 2004 727k2 and it will mow just fine then after i stop after about 2 hours the battery is almost dead It will not charge I can't find the issue any ideals
Have you checked the battery voltage before and after starting the engine? A faulty voltage regulator or a poor connection could definitely be the cause. What symptoms are you getting, and have you tested the charging system yet?What have you done to diagnose? Voltage regulator is suspect, could be various issues with wiring. You may have already done this, but I'd check/clean all battery/solenoid connections, connections to ignition switch etc. Voltmeter on battery, before starting, running, after running, etc.FNF
Look for a bad fuse.Hello I have a 2004 727k2 and it will mow just fine then after i stop after about 2 hours the battery is almost dead It will not charge I can't find the issue any ideals
The tractor won't charge the battery, or the battery won't take a charge?Hello I have a 2004 727k2 and it will mow just fine then after i stop after about 2 hours the battery is almost dead It will not charge I can't find the issue any ideals
