Echo SRM225 Head Maintenance
Propflux01
I have a 225 that I’ve had for about 12 years now. It’s been flawless so far. But I do wonder, on the gearbox for the trimmer head, does it need any kind of maintenance, like a degrease or gear lube of some kind?
Is there a bolt on the side of the gear head?
You are fortunate to have an older SRM225 with the grease port. Newer units have sealed bearings and no grease port.
