filmteknik
- Jul 21, 2026
- 13
I think it broke initially by the crankshaft then again along its length. Punched a hole in the side of the crankcase. I can get a used rod for just $15. But I'm not sure I'm up to the level of complexity of dismantling an entire engine. I pulled the head and pushed the piston out with a tool using the new hole. What's the likelihood I can push the piston with replaced rod back in and attach it to the crankshaft using the hole which I can enlarge? I would screw some sheet metal over the hole and use red RTV.
