andrewslarge
- Sep 20, 2016
- 171
The one in the back is so this engine can be used on other equipment and you can still check/ fill oil. Just make sure oil is almost about to overflow and put the black cap on.
Once I looked and saw oil down the hole. Wrong! It threw a rod due to low oil. I learned don’t guess. Fill til almost to overflowing when level.
