first_wang
- Jul 23, 2026
- 9
I have a Toro 21472 that won't start. I tested it by spraying starting fluid into the air filter. When I pull the starter cord, the starting fluid sprays back out of the air filter instead of being drawn in.
What could be causing this, and how would I go about fixing it?
Additional info: spark plug shows spark, and there's some compression resistance when I block the spark plug hole with my finger.
