Vibrations on my ZT34
When you have a mulch kit that is properly designed and you know how to use it properly, they do a great job. Yes, you have to learn how to use it!! I’ve have the mulch kit on my 1996 Toro 16-38XL and have neighbors who actually ask to use it because of the way the lawn looks when finished. Only time I don’t like the cut is when I can’t cut dry or grass is too long.
Not all have the time to keep a manicured lawn. With that most mulch setups are terrible at cutting grass without clogging. The only dedicated mulch deck that been though my shop has been the JD Freedom deck.
But even normal decks on some models have discharge problem in heavy grass cutting [tall grass]. The worst I have seen have been on Gravely mowers. I have had shut the decks move to a cut area, raise the deck, cut off the deck, let the clippings drop, and then with the deck still raised re-engage it. It is a rinse and repeat as long you cutting heavy grass. Yet I can take a Super Z and knee high grass with minimum problems.
One key thing with mulching is to travel slower giving the decks time to clear the clippings and always cut dry grass.
I definitely don’t have a manicure lawn, but I do have a unit which does a great job of making it look good with minimal effort.
I am always happy to hear someone got their setup working right.
These old Toros had decks designed for mulching or side discharge. There is a reason that Toro had the best walk behind mowers and tractors until 2005. They stopped producing their own tractors then and since 2021 the quality of their walk behind has also gone down hill.
hlw49
Yes I agree you do have to learn how to use it. you need to mow slower.
MParr
Older Gravely mowers are picky about blade choices and deck setup. Some of the older deck designs have smaller discharge openings. Gravely mower decks perform best when they are completely level all around or 1/8" higher in the rear. Aftermarket notched high lift blades work best on Gravely mowers.
bullet bob
I'm running G5 gator blades with the slightly heeled deck. HD ZT 60. Didn't use the mulching blades that came with the mulch kit after 2 seasons. Lousy summer cut. Mow slow, mow dry and don't cut too much at a time.......
