Motor oil
Auto Doc's
Hello Ozcub,
You pose some interesting questions.
I take the dash to mean from 10 "to" 30 viscosity, ranging from cold to hot.
Lake Speed Jr. has a site called the Oil Geek and I am sure you can find much more in-depth answers about oils there.
Ozcub
Hello Ozcub,
No , I am good with your answer , Thank you anyway
hlw49
Had a salesman describe it like this one time. Said it was like the principal of Spaghetti when it is cold and dry the additive to make the higher viscosity shrinks like spaghetti when it cold and dry. Heat it up and it expands like spaghetti when you add water and heat it up. Who knows
And the battle of the oils begins....a very slippery subject.
