Toro Max 77504 creeps forward in neutral
Gary9
Brand new Toro Timecutter Max creeps forward in neutral and tracking wont steer straight.
Jonmower
I have a Toro Titan and I am guessing the control arm connection to each of your hydrostatic transmissions is the same on yours. The control arms would connect to the transmission near the rear of the mower. A photo of mine is given below. If it does look like this, the bolt on the upper right (the one on the control arm rod ) can be adjusted to control both speed and creep. Twisting the bolt conterclockwise (looser) makes this side go faster, clockwise would go slower. This will address steering--either slow up the fast side or speed up the slow side. Just adjust 1/2 turn at a time as it is pretty sensitive.
Creep is another matter. I think Toro cut some corners here, as, at least on my model, this same nut addresses both creep and speed/steering. From my service manual, to adjust creep you need to jack up the back of the mower so both wheels are free. Then I put a bag of sand on the seat so I could start the thing. Start and then put in neutral. Twist the same nut I mentioned above (control arm nut) until the wheel does not spin.
The big downside is that if you stop creep you also will slow down the max speed. This is just because the same rod controls both, and, at least in my mower, the forward motion of the steering arms is limited by the metal frame around them. This kind of bugs me, as it's a clear design tradeoff. Many other mowers have a separate Return-To-Neutral adjustment available. I chose to live with a little creep to keep my speed up.
[I am really tempted to take a grinder to the metal frame the limits the forward motion of both steering arms. I bet removal of 0.10 inches would be enough. This would let me stop creep and go fast! Damn the warranty, full speed ahead!!]
If it is new, DON’T TOUCH IT. This should have been adjusted properly by the dealer. You messing with it can void your warranty. Back to the dealer and have him adjust both the steering arms and creep. A dealer who doesn’t do proper setup will probably try to say you caused the problem.
Jonmower
Correcting tracking might also be in your user's manual. It's in mine.
It may be in the manual, but why take a chance on voiding the warranty? We have a dealer in this area which will do anything to pass the cost of almost everything, because his labor rate is higher than what warranty will pay. I’ve done more than one rework when the customer didn’t like what he was being told it would cost him. He’s part of the 5% in every industry. Good dealers make sure setup is done properly. If purchased from the big box guys you may be out of luck, another reason to purchase from a dealer.
hlw49
Where I use to work did a PDI on every mower that went out the door. We had very few come backs.
GasSniffer
It's almost like dealers aren't even testing mowers before they go out the door.
Auto Doc's
If this was a box store purchase, it is unlikely that it was test driven to verify proper operations. It needs to go to an actual dealer to have it corrected. The box stores usually have an area dealer "flunky" perform the PDI setups.
Sad but true, they just sell the product.
VirginiaIron
….[I am really tempted to take a grinder to the metal frame the limits the forward motion of both steering arms. I bet removal of 0.10 inches would be enough. This would let me stop creep and go fast! Damn the warranty, full speed ahead!!]
I would take the 0.10” off the lever to save the beautiful paint job, although that heavy paint coating just might be what’s keeping you from full movement.IMG_5523.png
