Leaf Blower?
Prada
Anyone else feel like a leaf blower for lawn care is kind of overrated? I mean, I get that they clear off driveways and patios, but half the time it feels like I’m just moving the mess around until it lands somewhere else. I was thinking of picking one up one of these Novorik leaf blower for the yard, but not sure if I should just stick with a rake. Does a blower actually make lawn care easier in the long run, or is it just noisy yard clutter?
Thanks
If used properly, I’ve found that leaf blowers definitely have a place in lawn maintenance, especially as you get older. Raking at my age, mid70’s, is too hard on my body and the blower makes it much easier to clean up my lawn.
Tiger Small Engine
Anyone else feel like a leaf blower for lawn care is kind of overrated? I mean, I get that they clear off driveways and patios, but half the time it feels like I’m just moving the mess around until it lands somewhere else. I was thinking of picking one up for the yard, but not sure if I should just stick with a rake. Does a blower actually make lawn care easier in the long run, or is it just noisy yard clutter?
Thanks
Use a rake and a broom for a few months and get back with us.
the.doc
Sometime years ago I parked my mower and hired the lawn done. Those guys really loved their blowers. That's when I started getting bare spots in the lawn. At least it seemed that way to me. Then they quit, and I started doing it again. I was eventually given a blower. I use it just to clean the top of the mower deck. The mower mulches the leaves.
Ed in Virginia
Thanks
Overrated? Not for me. I maintain a little over two acres with many mature trees, including gums and beech trees. I use a variety of blowers to blow leaves, limb debris, gum balls, yada off the lawn areas into the surrounding woods or an open field. I use a battery-powered blower for the little jobs like cleaning off the porch and deck, and blowing leaves out of the garage and my shop. For the lawns, I use a gas-powered, hand-held Stihl, a gas-powered Stihl backpack blower, and a walk-behind blower with a 9hp Honda engine. I also have a blower extension for the Stihl handheld that I use to blow leaves off of the gutter screens - it makes a quick job of doing this task.
AChrome
Ed, I have an acre of sweet gum balls each fall you are more than welcome to them. If you want or need them. Won't charge you a dime for them.
jagg2236
Thanks
I clear 1 acre with a big Toro electric blower. Yea the cord is a pain but..... First off you have to work with the wind, not against it. Then pick them up with my tractor vacuum rack.
