Robert Boudreau
- Sep 21, 2025
- Threads
- 1
- 13
Status report: I have finished all the work, cleaned the engine, checked the wiring, fuses and cleaned all wiring connections. Started the mower (I noticed a little surging - though not consistent) and mowed for an hour or so. The mower was running good. Then it shut down. I checked the ignition switch/wiring. It was cool. I noticed a small amount of white smoke - not much. With the mower outside under a noon sun, the lighting was good. To late to be brief.....but, what I discovered was a leak down around the breather cover cover. However, it was not leaking from the breather gasket. To me, it looked like it was a possible combination of oil and gas. I say that because the fluid was neither clear or dark (like dirty oil). Again, the fluid (that I could see) was on the top/backside of the engine (as in above the coils).
My guess (I am not a mechanic) is that the engine is running hot and shutting down. I believe this accounts for the lack of visible gas in the fuel filter - once the engine was started (especially since I had previously eliminated all other possible fuel issues).
With this said, I am wondering if I have a head gasket leak??? Would that account for a possible vacuum leak (accounting for the lack of gas issue)???
