GiLinFtLaud
 - May 26, 2020
- Threads
 - 2
 - 22
Thanks! I will try that.I forgot the mention the connector for the solenoid on the bottom of the carburetor. Gently move the connector from side to side and see if the engine acts up.
The pins on the harness connect tend to spread and lose proper connection over time.
If that solenoid is an aftermarket, they always have trouble with connector fit issues.
I also plan to adjust the pitch of the fuel line to the carb, so it does not sag.
