i am working on a Ferris 5900536 model number. unit will not start, i mean nothing. no power. all safety switch's replaced. Ignition switch replaced,
mmoffitt
  • / i am working on a Ferris 5900536 model number. unit will not start, i mean nothing. no power. all safety switch's replaced. Ignition switch replaced,
Did you ever go through the procedure I posted to pinpoint a cause?
Don't want to be a trouble maker ....but of course not...BASICS!!! why spend money on parts you DO NOT NEED! Thanks for your always, ok 99% of the time spot on help...I have learned a lots from folks like you and the other well-seasoned veterans on this site. Be well Happy Cutting!
mcspeed
Great info here! I’m always amazed by ungrateful first time posters. Those that have responded, your efforts are appreciated as I know I’m still learning.
wingstrut
Unbelievable!
Auto Doc's
Some people live to work, some people work to live, while there are still many more who just watch from the outside and wonder why work at all.
outdoorpowermike
A bad pto switch will not let the motor crank, just sayin.
outdoorpowermike
Wire ends do break inside pto harness plug! Look closely and maybe you will see half the gold wire end missing.
outdoorpowermike
A bad pto switch can be the problem or a broken wire end inside the pto switch harness. Look closely at each gold color wire end foe a 1/2 missing tab.
