SeniorCitizen
- Aug 28, 2010
- Threads
- 144
- 2,324
The next time you have the chance measure the length of the spacer and compare that measurement to the distance apart the 2 outer bearing races will be when seated completely .Not sure what you mean by pushing the outer race with fingers. I use my shop press to disassemble and reassemble. Attached is the spindle parts, nothing complicated.
If the spacer length is a few thousandth less than the other measurement you're good to go . If it's not less the bearings will have a short life . A BIL had a repair shop replace the bearings and the spacer was omitted on re-assembly . He was calling me within an hour because of a noise he was not familiar with .
I prefer the top bearing to be free floating and that's how most are .
