Backfiring through the exhaust
PTmowerMech
407777 0188 B1
On a service call, started out, this thing ran like crap. Lot's of back firing through the exhaust. After about 10 minutes of it running & mowing, it seemed to clear up. It was still backfiring, but in spurts, it would completely clear up for several seconds. Maybe even a couple of minutes.
So I thought maybe it was just some junk in the carb that made it's way through. A couple of weeks later, customer calls and says it still running bad and that it wouldn't even stay running. So I picked it up and brought it home. (like a dummy, I didn't even try to crank it there)
At home, I crank it, and it's still got a little back fire issue. But nothing major, like it was the first time I cranked it. I throw on a set of new plugs (RC12YC). Of course that didn't change anything. But it eliminated the possibility of a bad plug. I ran it for about 10 minutes and the plugs were spotless.
So I guess the question is what could make it run like crap one minute. I don't want to do nothing to it, return it to the customer, only for to start doing it again.
Like I said the only real symptoms now is the slight exhaust backfire. I remover the air filter so I could see down in there, and didn't see any carburetor back fire.
Auto Doc's
Disconnect the shut off wire on both coils and see how it runs. The coil shut off wire has tiny diodes that will go bad and create cross firing issues with the coils.
They make several coil harnesses for these so be careful to match the correct one to the date code.
Flywheel key or new cam time.
Tiger Small Engine
407777 0188 B1
First thing I would do is clean carburetor, run and test under load. That doesn’t do it, check/adjust valves.
PTmowerMech
Tried your suggestion but, nothing changed. But I have a side question about what happened when I tried this.
With the wires disconnected from the coils, then turning the key off, 3 seconds later, the engine dies on it's own.
Reconnected the coil wires, then turn the key off, it dies right away. So how is the engine dying with the wires disconnected, 3 seconds later? It shouldn't die at all from turning off the key. Should it?
Auto Doc's
Hello PTmowermec,
Even though you disconnected the coil kill wires, the anti-backfire still has the ability to shut off the fuel in the carburetor when the key is turned off. That creates a slight delay before the engine winds down.
PTmowerMech
The carb is clean as a whistle. Even the bowl had almost nothing in it. The valves were at about .06. So I didn't mess with them.
Any back-firing through carb or muffler is either cam or ignition timing out of whack.
sgkent
or mixture problem. Unburned gas can ignite when exposed to additional oxygen, and a lean mixture can burn so slowly due to distance between the molecules that it can extend into the next exhaust stroke when combined with lean-misfire. I would use the choke if it has a manual choke to see if it improves with a little choke. That will tell if lean or not.
