I need a plug aerator that is reliable, sturdy and won't break the bank
toddsyr
  • / I need a plug aerator that is reliable, sturdy and won't break the bank
Hi folks,
Running around my 1/2 acre yard with my John Deere X570 lawn tractor tends to compact the soil, especially where I turn a lot. Yes, aeration, probably annually, is the answer. But.....
The gas powered ones run over 10 grand. That's a lot of loot for as much as I'll use it. No, I wouldn't justify the expense by doing other lawns.
We paid to have it done last year and ended up having weeds transferred to our yard due to the machine not being cleaned between uses. We're not going that route again.
Soooo..... What are the more affordable options for a reliable/durable plug aerator that will be used on harder soil and can be pulled around by my X570? I realize it won't be cheap, just wondering about decent options. Thanks.
It is a piece of kit you will use for 1 hour once a year
Go hire a self propelled one or get a lawncare specialist to pop in and do it one a year
IF you lived to be 1000 years old you will still pay less by doing either of these .
bkeller500
You could rent a plugger. You also might be exposing weed seed imbedded and dormant as you aerate ( just a thought). The Agri-Fab pluggers are cheaper and if you wait and do your aeration on a wet lawn you will get good penetration, possibly adequate enough.
toddsyr
I found an affordable and effective way to aerate. It's called "Air-8". It's a liquid aerator you apply to your lawn. Works great on clay soils like we have around here. A guy up the street from me uses it and swears by it. Must work, his lawn looks great. I understand there are granular brands that you apply with a spreader too. Those one takes up to 3 years to take effect. I'll go with the liquid.
7394
Interesting.........
Projectnut
I'm a little late to the party, but many years ago I purchased an AgriFab plug aerator. Out of the box it did a marginal job. It took about 200 lbs. of weight to get full penetration which made it hard to raise the tines with the hand lever. Also, all the plugging heads were attached to a single. It made gouges with the outside sets of plugs when turning a corner.
The first modifications were to cut the axle into 3 parts and add outer support plates. I also added and bearings to each of the new sections. Now there are 3 individual axles with only 2 sets of plugs on each axle section. This eliminates the gouging when all plugging heads were attached to the same axle.
The original axle/coring head assembly looked like this:
Later modifications include a rack on the top of the frame to hold suitcase weights, and a modified trailer tongue jack powered by a modified windshield wiper motor to raise and lower the plugging heads. Here are som pictures of the completed project. I use it 2 to 3 times a year and about the same at the family cottage.
toddsyr
Okay. After a lot of hemming and hawing and indecisiveness, I actually bought something.
I purchased the John Deere LPPA40JD 40" Tow Behind Plug Aerator.
It's actually made by a different company for Deere but it's pretty sturdy and it works well.
It's supposed to pull 3" plugs. My plugs were about 2" or so but...... the ground was hard, to say the least.
You could not stick a shovel into it. I literally had to score the ground with a large knife first to get a shovel in.
The next use should bear longer plugs. Regardless, the lawn looked better in 2 days. After a few watering sessions you can also feel the difference when walking on it. It's much softer.
BTW, I used 175 pounds of block for the weight which is the maximum for the LPPA40JD model. There is also a 48" version available with a 250 pound capacity.
I got the 40" model so it will fit behind our shed and the fence.
BTW #2. I paid an extra $180 to have the unit assembled and delivered by my local Deere dealer. I work 60-65 hours a week so the expense was worth the time savings.
Thank you everyone for your replies. Much appreciated!
Most of those tow behind style aerators don't work. As in if you have hard pan clay soil, you have to get the moisture content perfect or it won't make cores/plugs. Too dry doesn't penetrate the soil. Too wet is a clay clogging mess.
Best to rent a machine that mechanically punches cores into your turf.
toddsyr
Yes slomo, there are many inferior tow behind plug aerators. The cheaper ones especially. i read they tend to bend and deform when loaded within their rated weight capacity. I did my homework though and am quite satisfied with what I bought. My John Deere LPPA40JD cost twice as much as the cheaper brands and held it's weight well. It is also highly rated by other purchasers. Yes, the lawn can't be too moist or dry. I aerated the day after it had rained here. The manual it comes with gives guidelines that are very helpful. As previously stated, I am quite happy with the results it gave. My lawn looks healthier and even feels softer after the aeration. I did rent a powered aerator once. It was not maintained well and was a waste of money. Your mileage may vary with that option.
