Kohler Courage single cylinder engines.
BGS Mex
Beware of these engines, especially used. Kohler only showed they had the "courage" to build them to self-destruct.
Valve cover leaks.
The top cover bolts under the flywheel fan shroud loosen at under 100 hours on average. Some break off while other will contact the flywheel bottom side while running.
And the "final nail in the coffin" is the engine block will stress crack on the top right and leak oil constantly.
I had this happen a few years ago that did crack the block. I Tig welded the crack and reinstalled the cover plate as attached shows. Torqued to spec and used blue loctite.
  • Oct. 23 2023 Closure Plate Fastener Bushings.pdf
Scrubcadet10
Moderator
Staff member
creative fix right there!
Wrenchit
Yep, they are still trying to beat the SV singles to death because of a few engines that had mistorqued top cover bolts, without locktite, and a few that broke the counterweight alignment rod which would break the bottom of the block dumping the oil. Later versions had gone 700-1000 hours easily. Anybody hear about failures on the 5400 series engines that was also a bucket style engine that replaced the SV singles. Didn't hear about those bolts coming loose or cracking the block.
Anybody remember the TH Triad DOHC engines. Seems nobody talks about that engine. The one were the timing belt cavity would fill full of debris damaging the belt, and required a debris eliminator hole on the bottom of the cover below the crankshaft pulley. Or if the engine overheated it would slide the steel cylinder liner down until the top piston ring would get above the liner and then the downward motion of the piston would drag the liner down into the crankcase resulting in it breaking both rods.. And Kohler paid for the Triad to Command conversion in Walker and Grasshopper mowers.
!00% on that!
The bucket series is easier to work on, at least for me, anyway.
Always liked to do the tear-downs at Kohler school on these.
Another of Kohler's bright ideas was,
Command series with the nylon of a plastic governor ball cage.
Easy to diagnose, pull the dipstick, and if the bottom is baked, with a dark brown color, the governor ball retainer is either shot or nearing the end of its life due to extreme overheating.
Ditch the cork design and make your own out of pressed paper gasket material. It will last much longer.
One can use a cereal box to do just that. Also hit it with some Permatex High Tack gasket sealant. Works like a charm.
