Customer states, hit a stump and now deck is making terrible noises
Tiger Small Engine
  • / Customer states, hit a stump and now deck is making terrible noises
A fellow brought his Dixie Chopper a month "it was running yesterday" quick look without touching it, it had been sitting in the weather, no breather tube on the valve cover, the metal air filter cover had a 3/4" hole where if had been banging around the stud that held if in place without a nut on top, no terminals on the battery cables, two front tires flat, I told him he needed to leave, I won't work for a known Lier, then I pulled the dip stick water was equal to the height of the valves, then he started to apologize, told him it will all be fixed or I won't work on it, then he is really nice and you will pay cash and have 30 days to pick if up or it will be sold for the invoice, he did agree to that, I machined a few parts, machined a bushing for the breather housing, when done I have never seen a Kohler that run so smooth Idle so low, tested the machine worked great, the bill, 758.00, he said I will pic it up and pay you later, told him you were not listening when I told you cash at pickup, you have 30 days, let one of your friends know if they want it, June 1, it will be sold, he sent his girlfriend the day before with a check, she was nice but did not know the deal, told her cash by 10.00 AM the next day that I did have it sold, she showed with the cash was here at seven AM
Those types of customers usually have several red flags before the work even starts. The signs are there not to be ignored. I know this only from past experiences. There is too much good business out there to be chasing the bad or borderline.
