jono252525
- Sep 7, 2017
- Threads
- 9
- 54
My friend as a Stihl chain saw easy start that will not start.
New gas, New spark plug, I have spark, I spray cab cleaner in carb but no start, I removed the spark plug and add a bit of gas in the cylinder but it lock up ( could not pull the cord ) I loose the park plug a bit to unlock and still no start.
The thing is that there is no effort to pull the cord but the engine is not turning more then a few turns when pull.
This special feature (Easy Start) seem not to turn the engine an off to start!
The manual starter as 2 springs but they are good.
