Help installing engine control springs
Coinhunter
Someway the bolt holding the choke lever, with all the springs attached came loose on my SV730 3043. After 3 days of searching I have actually found all the parts, spacer washers etc and the bolt to put it together. I cannot determine where the springs go. I found an exploded view of the assembly and I have it back together and mounted with a new bolt.Can anyone please help me by telling me which spring goes where. Or even better can anyone post a picture showing where to connect the springs exactly. Like in which hole do they go? My Kohler service manual doesn't help at all. See the attached photo. If the showed the back of the assembly or drew lines showing where the ends go it would solve alot of problems. Thanks in advance. Coin
Coinhunter
I posted thhis and within 5 minutes I found what I needed at Kohler. They provided me with a download link for the complete service manual. Thanks to all who read my post. Coin
