DaSouthWon
Hi Everyone,
I'm new here and this is my first post. After digging on the internet for several hours I'm unable to find an answer to what I thought was a simple question. I have a Honda HRC215 K1 SXA commercial mower that I have determined to be a (1995-2000) 21" 5.0 hp S/P Rear Bagger BBC Steel (Frame Serial MZAU-6100001 and up) with a GXV140 engine. I originally Sanford & son'd this mower when I saw it sitting on the side of the road to be thrown away. The deck, controls, and practically everything else on the mower were in great shape but the engine wouldn't crank. After a simple carb cleaning, blade sharpening, and plug change the mower cranked on the second pull and I used it, trouble free for about 4 years. The mower then developed a problem of revving extremely high when it wasn't under load (not a carb issue) and eventually snapped a rocker. I tore the engine apart, replaced all the seals, gaskets, bearings, valve springs, rocker arms, pushrods, piston rings, lapped the valves, honed the cylinder and put it back together. I didn't pay much attention to the internal governor, which I think is probably the reason I still have the high revving problem after reassembling the mower.
At this point I would prefer to just buy a new engine, take out the four or five bolts holding the old one in place, slap the new engine on and be back in business. I've found its not that simple, as Honda has fourteen million different engine configurations and evidently the gxv140 is no longer made. Does anyone know if I can replace the gxv140 with a gxv160, and if so, which version has the pto for the s/p shaft and same bolt pattern and crank shaft diameter as the 140? I hate to ditch the mower, the deck is still in great shape, I've just replaced all the cables and I don't want to spend $1,000+ on a new commercial mower when I can get away with putting on a $300-400 engine. Thanks for your time and advice. Brian
