Hsquad12
- Mar 6, 2013
- 12
So I found a 14 SB in the trash, hauled it home, cleaned the carb, set the plug added fuel and the beast fired up first pull and runs like a swiss watch. I have two low end sears mowers at home but this machine is clearly a class apart and seems worth saving for the engine alone. The external safety latch on the bbc was broken so I took apart the housing and removed the safety mechanism so I could check that the clutch functions. the clutch engages well so I figure it is worth investing $50 in a new bbc module and cables plus an oil change and filters etc. before i start spending money My final hurdle to get the basics functioning is i cant see how to easily to replace the (broken) transmission cable.
So, does anyone know if I need to pull the engine and transmission to connect the cable at the transmission end? I can't see much with the drive pulley in the way but I can move the selector level and feel the broken part of the cable plus all five gear position.
Any help would be appreciated.
E
E
