wjjones
- May 29, 2011
- 1,456
Does it have a primer bulb, and how does it look? If it is full of debris inside you wont be able to see it if you re-used the old one. The only other thing could be the gasket not mating to the engine between the carb, or as mentioned the fuel filter is clogged.
