Echo Pe-200 stick edger
I definitely need new ones. The tread on mine are so lo there's almost nothing there. And since the previous owner had chains on the tires for long periods of time, there are big nicks and notches as well. I was looking at Turf masters and turf savers. The ones on there now are kendas. Any thoughts?
A_tank96
Kenda makes a good tire. This may sound kinda off a little but Kenda Makes a lot of Recumbent and Bicycle tires with tire pressures running up to as high as 150 to 160lbs so if they're Kendas I'd have to say they would be a good tire.
What size tire are you talking about? I'll do some price checking and see what I can come up with.
My reply to thread button is working....weird. Anyway, Ric I'm going for 18x8.5-8 Tires. I'm widening them 1 inch from the base tires. Or if you can find 18x7.5-8 size tires that are smaller, those would work to.
A_tank96
