robert@honda
Honda has released a Service Bulletin for the HRR216VKA and PKA mowers to resolve a "Engine Won't Restart" issue.
ONLY mowers within the following range are affected: MZCG-8400001~MZCG-8669999.
The symptom is an engine that may not restart after being shut off before the engine has been fully warmed up. Often this happens when a cold engine is only run for a minute or two, stopped, then a restart is attempted. The issue is the choke plate remains fully closed because the AutoChoke's thermowax cylinder senses the engine is still cold.
The fix is replace the thermowax cylinder, insuring it makes full contact with the engine, and replace the AutoChoke control assembly if it is binding or not working correctly. There's also a small bracket that can help regulate temperature that may be installed.
If you have a mower in the affected range, and it has this problem, and is still under warranty, Honda will typically pay for the repairs. Delivery and pick-up of the mower to and from a Honda dealer is not included. You can find a dealer in your area at this link:
Honda Dealer Locator
Ask about Honda Lawnmower Service Bulletin #98, if your dealer isn't aware of it yet.
