Hello tractor survivors. My craftsman ytd 4000 24 hp shed its sump bolts this week. Oil mess , rattling and no idle . Found two retaining bolts completely loose and standing on their heads in front of the oil filter (tightening sequence #4, 8). Was able to start them by hand. Then I backed the other 8 off and performed the tightenign sequence in the intek manual. The loosened condition allowed crancase pressure to blow out part of the gasket which inhibited the fuel pump (apparently) so that the engine would not idle. After tightening the beast is happy again. With chagrin I note that craftsman at least placed the sump close enough the to frame to capture the bolts in loosened condition. With that kind of design cunning why not fail safe the fasteners (locktite blue?) to start with? Anyway check them periodically. The engine hold down bolts (4) were still tight.
