lifebeginsafterdeath
Hi to all & I'm new to the forum. I bought this unit new, as a package deal back in 9/2010. After getting it, i was having problems with it starting up upon turning the key. There was a ritual i was doing in order to get it started. When i turned key on, nothing. Not even a click. After i pulled the knob for the PTO, then the throttle, go around back & engage/disengage the transmission bypass rods, then i would get a click, couple more times & then it would start. Turning the key to the right, it shows 10.3 After reading the manual, not sure really how to tell what is hours & what is battery. I always thought it was showing battery voltage. Took the battery to Advance Auto, it needed charging at which they were kind to do. Put the charged battery back in, nothing. Not even a click. I go thru the ritual & get a couple of clicks but that is it. Now not even a click. I see i have a starter, battery, key switch, charging coil along with ignition coils. I also do see the spark plugs & carb. i am currently doing a tune up to put up for the winter. Would like to get my starting issue rectified. Any suggestions? I'm not employed now, am a DIY guy, so i definitely want to bypass dealer if at all possible. tks
