Belt issue
Rickcin
Have a 2005 Metro 36 inch and I just changed the drive belts. One side does not want to stay centered, in the groove so I would guess that something is slightly out of alignment ? I do not see where there are any adjustments, looks like just direct bolt holes.
Any advice ?
Thanks,
Rick
EngineMan
Check belt guides under the engine deck for proper adjustment. Adjust as necessary.
The disengaged belt should not drag or fall off pulley when guides are properly adjusted.
Rickcin
The belt issue is a wheel belt that does not stay centered, it drifts to one side of the double pulleys.
