Foreverwood
 - Jul 2, 2012
- Threads
 - 2
 - 4
My Poulan pole trimmer has started acting up. At first it would only stay running in the choke position which it would over rev in. I then took the carb apart cleaned it put it back together and now it starts but i have another problem. Now when I prime it gas shoots in the carb instead of through the return line. Of course at first i thought that i must have reversed the line although its hard to do on mine since the sizes are different. I was obviously amazed. I then thought could i have destroyed some check valve soaking the carb, but my primer bulb is external and was obviously not soaked. I then traced the lines one by one to make sure. Gas line  from bottom of carb to small line attached to filter in the tank, gas line at top connected to what is supposed to be the suction side of the primer. The suction side pushes out and sucks in. The side that squirts out still only squirts out. I'm guessing that a check valve should be in this purge bulb and miraculously has gone bad all of a sudden. Do you all agree? The saw will start now although it need revving up and the needle adjustment is either too much or too little within a quarter of a turn either way. Ive never had an adjustment problem like that. Help
