kohler cv20 carb not getting fuel.
BEACHES204
MOWER JUST DIED. AND WOULD NOT CRANK AGAIN. IF YOU PUT STARTING FLUID IN CARB IT WILL CRANK BUT NOT STAY PAST THAT.
I EMPTIED GAS TANKS AND CLEANED OUT. ONE TUBE INSIDE WAS BROKEN. SO FIX THAT.REPLACED FUEL LINES, FUEL FILTER, FUEL PUMP. FUEL NOT EVENING MAKING TO FUEL FILTER. WHAT MIGHT BE CAUSING THIS?
Blow up the pipe to the tank, and see if you get fuel. with the cap off.
as to be a blockage something blocking the passage of fuel.
When you do get fuel, clean out the carb.
