i have an older bolens bl250 trimmer that i'm cleaning up, and i'm stuck on one problem. it runs strong, but the kill switch doesn't kill the engine. based on how it's wired, it appears that the switch is supposed to ground the coil/magneto, removing spark from the spark plug. well, the switch works, the wiring to and from the switch is good (all checked with a meter)...but the switch won't stop the engine. i either choke it or pop the plug wire off.
any ideas about how to get this kill switch working?
thanks in advance!
dan
thanks in advance!
dan
