simplicity 2210 landlord
rachel11
recently purchased 2210 landlord and have a few issues. I am unable to locate an operators and parts manual.Parking brake wont engage. Throttle wont hold its position, it keeps slowing down, you can see the cable easing back in. Carb picture or diagram might br helpful. I need a part number for the deck belt. Thanks for any help. I have spent a lot of time elsewhere looking for info. on this. About ready to give up and sell it.
Need a Unit Model number to help you. It begins with 169.
rachel11
thanks for reply Rivets. According to info.I have my 2210 was mfg. in 1969 and has a mfg. number of 496. I know only 3 numbers long.
Won't get back to the shop til Tuesday. Will try to remember to look into this problem in my old books. Do you have any engine numbers? Didn't realize it was that old. Be pactient, we will get the info.
rachel11
The engine is a B&S 10h.p. Number is 243431 0123 01 6304301 thanks
rachel11
I took your advice and joined that forum, butg coud not find the manuals I needed.
Please go back to the website and search in the manuals section. Type in this number in the search box (990497) as what you are searching for. it should give you your manual. I just tried it. This number was part of the address I sent you.
rachel11
I cant download from that website. they said I dont have the required number of posts as because of being a new member. Besides the throttle issue as wont hold its setting, it keeps going in, I need info on how to remove and adjust deck.
