Hi All! I have been checking this site out for some time now but this is my first post. This is a frustrating problem so I hope with all of the wisdom you all bring to this forum I can finally solve this mystery. I have a 2007 Hustler Super Z with a Kohler 30 hp motor. Model cv750-0026. At first you could mowe for several hours with no problems at all. If I shut it down and went to mowe somewhere else it would run for a while and then would loose power and run on one cylinder for several seconds and then kick back in to full power. This would go back and forth until I finished the lawn. The periods of running on one cylinder became more and more frequent until it got to the point it did not come back to both. I put on a new carberator but this did not help. I believe I found the side that was cutting out and replaced the ignition module.This seemed to help but when mower started back up it seemed to run a little rough,pop some times, like it needed a tune up. After mowing with it for several hours it seems to be running better but will still cut out of one cylinder for very breif periods occationally. Any thoughts?
Thanks for your help and sorry for the long post!
