trobinson017
I have a Homelite Trim n' Edge trimmer, 25cc, model UT20024A. Worked fine until yesterday when it stopped dead in the middle of trimming. Plenty of new fuel mix in the tank. After initial troubleshooting I drained the gas out of the tank and along with it came some tubing pieces and the fuel filter. Do'h! I got new tubing today (clear tubing!) and put it all back together, but I'm not sure if the tube lengths are correct or if they even need to be certain lengths. For that matter, I don't know what the non-filter tube does. It had nothing attached to it as far as I can tell. Carb overflow? Air input?
Anway, once it was all back together I tried to start it. I pumped the bulb once and it stayed flattened. Normally, it pops right back up so I can keep pumping it. But now it always just stays flat. Seems like this should be an easy fix and may be related to the tubes I replaced. Oh, there is fuel in the bulb and the filter tube has fuel in it. The other, uknown tube also has some fuel in it but not completely. It's like some fuel came out of the carb into it when I pushed the bulb down.
Any idea what's keeping the bulb from popping back up? Any other help on getting this baby running would be much appreciated. My yard looks like crud with only 1/2 of it edged.
Thanks!
Trob
Thanks!
Trob
