Briggs & Stratton 22hp running issue
bodean
This may get a little long, but niece is having running issues with her 3 year old JD LA 145 with a 22hp twin. I have never had an engine do this before, but here goes;
It ran fine 2 weeks ago when we last used it, then the next time it did not want to start. Had to use starter fluid and when it did start, it ran very rough and would not accelerate. Black smoke began to come from exhaust and the fumes would burn your eyes and nose. It sounds like it is hitting about every other stroke or so and barely running fast enough to idle. So far, this is what we have tried and found out.
The coils, plugs, wires, are all good. It does not have a firing problem.
All the safety switches were checked and are working as they should.
This pretty much eliminates an electrical problem.
The carb was removed and thoroughly cleaned as well as the tank. The fuel pump is working as it should and we are convinced it is getting enough fuel.
The compression in both cylinders is 150 psi.
The valves are all working perfectly.
So, this is what I was able to observe.
The engine will start and run smooth initially...uhh sometimes. Sometimes it runs as mentioned above for a while, then begins to run smooth after a few minutes.
When the engine runs smooth, it can be accelerated slowly, but when it runs rough, it can not.
If I try to increase engine speed too fast, it will revert to running rough again.
If I engage the blades while it's running smooth, it begins to run rough again.
Seems that anytime there is a sudden engine acceleration, or a sudden load such when the electric clutch is activated, the engine will revert back to running rough.
Whenever the blade is engaged, or the accelerator is moved too rapidly toward high speed, the gov. lever drops completely and remains there until I either lift it by hand, or the engine is shut off. It is not binding as far as the action of the lever and rods. It's almost as if when the gov. lever falls too low, there is something keeping it there until it is forced up or the engine is shut down.
We have had 2 very knowledgeable lawnmower mechanics to check it out and both are scratching their heads right now. Is it possible that the gov. shaft from the engine has slipped within the lever and is out of adjustment? Is it possible for the gov to go so low that it actually is being held down by the forces of the engine? Both gov springs are connected.
From what you say the first thing I would do is totally rebuild the carb. The black smoke indicates a rich mixture. I would be looking for either a bad needle and seat or bad float.
Is this a Vanguard engine, and has the air filter been changed recently. Briggs has two air filters that look similar and both will fit, the problem is one of them doesn't allow enough air flow and causes a rich run situation shortly after being installed, like within about 10 hours. It is a round air filter about 2 inches tall. If you have this air filter, start the mower and remove the air filter and see if it smooths out.
bodean
The air filter is off for all the testing that we did. Putting it on has no effect. Mower mechanic friend of mine (shade tree version) says these engines are notorious for valve seat failure and plans to check that out later this week if all else fails. He's already had to repair 3 engines this season for valve seat problems on V-twin B&S engines. All of them required head replacement due the extensive damage caused by the loose seat. I personally would have thought that if the valve seat failed, then compression would be lower than 150 psi. He plans to replace the carb with another known good carb, next. I still believe it to be a carb or gov. issue.
jtcarter1
This may seem like a dumb question, as you have gone through the mechanics of the issue quite thoroughly, but how old is the gas you are using?
reddragon
i still think it needs the carb done again....something was missed, is my guess
bodean
The only dumb questions are the ones that don't get asked.
The gas was pump fresh.
bodean
Friend replaced carb with a known good one today. It had no effect on it. He and another mechanic checked it out today and he now believes what I had originally suspected before I let him take it to his shop. They both have come to the conclusion that the governor is having internal issues. Whenever it bottoms out on sudden acceleration, or when blades are engaged, it does not rebound easily w/o either lifting it by hand or by shutting engine off. Even shutting engine off does not always let the gov. rebound and when you lift by hand, it has a slight catch to it on occasion. He plans to inspect it next.
reddragon
you can always set your throttle with a TACH manually and disconnect the governor...itll save you cracking open the engine
bodean
Well, it has been officially determined that gov. was broken (about half dozen pieces). He replaced the gov. , cleaned the engine and oil pump, and re-assembled everything. It only solved half the problem and there was still some spitting and sputtering. He then re-installed a known good carb and it runs great now. He re-installed the original carb and it went back to spitting/sputtering. Is it possible that the carb caused the gov to break, or vise-versa? It's weird that it had 2 problems going on at the same time. What do you think? Now we have to find a deal on a 79130 carb.
