If you're interested, I have a couple of threads on going through an engine and rebuilding some items on Craftsman snowblowers here: Restorationmen Forum Project How To's
Couple of things to note - I recommend using a brass wire brush on the piston and valves to clean off carbon. They won't scratch or cut like steel wire brushes do.
Check out any gear oil you put into the auger gearbox. You have a bronze gear in there and some of the GL5 oils will attack the metal. You want GL4 or (I can't remember the name) GL5 that doesn't attack bronze. Many manufacturers recommend using 30 weight oil so check what the mfg recommends.
Good luck and congrats. Looks like you have a good machine there.
