Ignition Modules for old tecumseh 10 hp motors
Russ Gilday
My John Deere model 112 ( a 1969) has a solid state ignition module which is no longer available thru any J D dealers or any used parts place I have checked. I have been told there is a replacement setup for it but so far no one has proved that one exists. Anyone know of such a thing or where i May get a good used one?
SONOFADOCKER
Try you tube . I think I saw a guy do a conversion like that .
poloman
Try overnight-solutions.com
Have you got the model numbers off the engine?
greggn
check ebay under joesoutdoorpower.
610759. That should be the part number for the solid state magneto, if it is mounted under the flywheel. Please double check your model number, I could not find the one you gave.
