handirifle
I have an old Murray wit the 20HP Brigg opposed flat head engine. I have done a lot to this thing to keep it running, and have "fixed" this problem before but it keeps coming back.
The problem doesn't always go by the same sequence, but it sometimes does (clear as mud huh?) but often, it will run fine on startup and for first 5-10 minutes. I thought I had it fixed once today and mowed with it for about 190 minutes and it came back.
What it does, is say you are at 1/2-3/4 throttle, the engine will rev up to the throttle setting level, then the revs drop off, almost to an idle, then right back up again. It will keep repeating this process the whole time, from then on. It is not shutting off, it just sounds like you are mowing and playing with the throttle, rev it up, pull it back to idle, rev it up, pull it back to idle, just about that fast.
I have gone through the carb, several times, and replaced the fuel pump once and rebuilt it once. Each time I have done the work, mostly on the fuel pump, it corrects the problem, for a few hrs of run time, then back again. I have also replaced the fuel filter (it's one of those red screens actually) twice. This thing cannot be going through fuel pumps that fast.
This really does not run like it has ignition issues, I believe it HAS to be fuel related. Is there a possibility, something tiny is floating around in there driving me crazy? Should I replace the screen with a REAL fuel filter, and the lines while I am at it? Does that sound like I am headed in the right direction?
The fuel line comes directly from the bottom of the tank, up to the screen, and on to the fuel pump.
This is the three screw fuel pump, for those familiar with the old opposed twins. There is a 4 screw model also, but not mine.
Thanks
Thanks
