Run dry or store full?
BackyardBrian
Hey fellas, Brian again. First real winter with my own mower up in the Northeast, shed gets cold cold.
Been readin up on winterizin since every mower before this one was somebody elses problem lol. Found a solid walkthru, covers the deck, stabilizer, oil, battery, blades, mothballs for mice.
Hung up on the fuel question tho. Run it dry or store it full. Im on regular 87 with ethanol from the station down the road. Guide says dry for ethanol gas, but plenty of guys here swear by full with stabilizer either way.
Whats actually worked for yall long term. And if you run dry, do you drain the carb bowl too. TIA
Hello B.,
Actually, I like to use mid-grade E-10 with the correct amount of fuel stabilizer. I have been using Ethanol Shield for the past couple of years and not had any problems. I also use Stabil Marine but gave up on Stabil red after having gelling problems.
My advice is never using budget grade E-10 or the new E-15 because that stuff is often mixed with a percentage of reclaimed contaminated and expired fuels. That stuff hardly last 30 days without making carburetor problems.
If you have reliable non-ethanol available, then spend the extra money and use that.
During regular use season stick with the mid-grade E-10 fuel because it will not sit for long periods.
Due the way carbs vent and even running them dry still leaves fuel deposits in the jets so it best just keep the engines fueled then start them up once a month and run for at 5 minutes to refresh the fuel in the carb. Especially important for stand-by generators as you never know when you are going to need them.
Additional notes:
Fuel sitting in a standby fuel can is not "fresh fuel".
Adding stabilizer to old fuel does not "refresh" the fuel and give it back its lost volatility.
Adding a "little extra" fuel stabilizer will not magically add more life to fuel.
Additional notes:
Post by HI officer, not to be confused with an AI.
Happy Turkey Day.
Been on both sides of this one over the years. I used to run the tank dry on my TimeCutter, but with the JD345 I'd usually fill the tank and add stabilizer.
Both have come through winter without carb problems, but I can't say if that's because of what I did or just good luck lol.
This year I'm planning to fill both tanks with fresh fuel, add stabilizer according to the label, and run each engine for a few minutes so the treated fuel gets through the system.
I wouldn't count on stabilizer to bring old fuel back, though. Starting with fresh fuel makes sense either way.
Thanks fellas, seems like filling it up with fresh gas and stabilizer is the way to go, then running it a few minutes so the treated fuel gets into the carb. Happy Thanksgiving yall.
Well I look at the stabilizer issue as this. Putting stabilizer in old fuel just stabilizes it as old fuel where adding it to new fuel helps to greatly reduce the aging process of the new fuel.
