Running like new for a week after replacing the carb and fuel pump sounds promising. Did it run well the whole week, or was it still acting up now and then?
Does it run rough right from startup, or does it start acting up after it's been running a while? I'd want to know if it changes as it warms up before chasing anything else.
For the whole week it ran like a new one. will do some more checking.Have you done any testing on fuel flow? How is the flow from tank to fuel pump? If it isn't free flowing, take off the fuel cap, and find the fuel pickup with a flashlight, and fish out the pickup. They often have a filter on the pickup, that can clog up as the engine runs. If you pull the pickup off the line, you can backflush it with air or carb cleaner. Some have check valves, and they don't backflow. Get the filter clean. If this helps, you need to clean out the tank.
If flow to pump is good, check from pump to carb, and check the pulse line from pump to engine. Make sure it's a good connect. If there's any doubt, replace all fuel lines. They break down on the inside, so you don't see it. If they are hard, replace. It doesn't cost much. If you're replacing lines, do the filter too.
Runs rough from the start up ran well like a new one for a week or more.Running like new for a week after replacing the carb and fuel pump sounds promising. Did it run well the whole week, or was it still acting up now and then?
