Parts source requested
Thank you auto doc!! Good info to know...I've spent my years doing restoration work on classic cars, but I'm really looking forward to reconditioning this little guy, it's going to take me back to the 8th grade, and in power mechanics class...surprisingly My semi aging brain still remembers most everything....but I want to learn about a coil I'm told that will replace the need for points if there's an application for this little motor 😀
It's not the things from 60 years ago that I have trouble remembering, it's the things from last week, yesterday, even earlier this morning that I can't remember. Yet I can still remember my oldest sister's wedding from 70 years ago last week when I was just 2 years 3 months old. They tried to get me to be the ring bearer and I refused.
I have a very similar B&S engine that belonged to my dad. It's sitting in my barn as a project. I've wanted to restore it for years. I cut my teeth on small engine repair at age 10 when I rebuilt a Clinton 3.5hp engine off a garden tiller, with Dad's help, of course. Then it was a larger Wisconsin off a Bolens 800 tractor. The small engine bug bit me early. This little B&S has been waiting many years for me to get to it. I think it's about time to put it on the bench. I had forgotten about it until I saw the picture you posted. Thanks and Good Luck.
Thanks! I got mine torn down to a bare block last evening and it was quite enjoyable! You should go for it! The only issue I've had is finding part numbers since it's so old...
It’s a labor of love and satisfaction.
Looking forward to seeing your progress
Thank you! I just have one last battle, the rusted out muffler doesn't want to come out..got it soaking in pb blaster for a while, and will add some heat, and hopefully it will break loose...
