Parts source requested
Hello! New member here...I have a 2hp briggs, 60102 0226 01 6504973 motor I would like to rebuild.
I've been on the briggs site, and amazon but have not been able to find a source to buy a gasket set, and rings...someone guessed my motor might be a 1965?
Thank you in advance for any advice! Slotman
Hello S.,
Being that this is an aluminum block, I would say it is a basic 6 cubic inch engine and rated at 3hp. The earlier cast iron B&S engine offering did have a 2-hp and even a 1-hp with a foot crank start mechanism.
I am digging around for my quick chart parts reference book from the 70s when I started out in an AG CO-OP repair shop working on small engines.
If I can find it, it will have a lot of part numbers. I will update when/if I find it.
This engine is in very good condition for being 61 years old. I recall that they originally most of them had an oil bath air cleaner, and they were messy to deal with.
Parts will be difficult to find, but not impossible.
Hello S.,
Thank you auto doc!! Good info to know...I've spent my years doing restoration work on classic cars, but I'm really looking forward to reconditioning this little guy, it's going to take me back to the 8th grade, and in power mechanics class...surprisingly My semi aging brain still remembers most everything....but I want to learn about a coil I'm told that will replace the need for points if there's an application for this little motor 😀
That engine will definitely work on a Mclane edger. I have a few. It will also work on a small Craftsman rear tine tiller. I picked one up in Atlanta and restored it. Owner ran it low on oil and the connecting rod broke. I got lucky there wasn’t more damage.
The key is fill oil to the top 3/4 of the filler cap threads. Change oil annually or every 25 hours and that engine will keep on running.
Thank you for the tips! The oil in this one looked pretty ugly but at least it had oil in it...I found it in the bushes of a house built in the year 1900, still bolted on the McLane edger, the good thing is that not a single part appears missing, I thought I read the McLane company is still in business...
I have 6 McLanes with various Briggs engines.
I have given two away as gifts to family members.
They are awesome Edgers! You can still get parts and they are still in business. If you post a picture of the edger I can estimate a value.
A new one runs over $1000!
This is the frame currently, motor was on until yesterday...I'm considering media blasting it to bare metal, then following up with etching primer, regular primer, then matching the color as close as possible.
Finding this brought back a memory as a teen, of my neighbor having a McLain, one day as I drove by as he was using it, and it chucked a decent size rock thru the side window of my 58 pontiac....so I will be mindfull of this when I use mine, one wheel has cracking on the rubber. 😀1000015474.jpg1000015473.jpg
