Parts source requested
slotman
Hello! New member here...I have a 2hp briggs, 60102 0226 01 6504973 motor I would like to rebuild.
I've been on the briggs site, and amazon but have not been able to find a source to buy a gasket set, and rings...someone guessed my motor might be a 1965?
Thank you in advance for any advice! Slotman
Briggs does not list those engines anymore. parts tree does and superseded part numbers. parts are listed on E-Bay
Yes, it did seem so....I'm just hoping there must be a business somewhere that still sells a gasket set, and rings for these motors, it would be a shame if it's just a boat anchor due to no available parts...:(
google the engine number then pay attention to the date code when looking at parts. The engine code is 60102 0226 01 the date code is 6504973 = 1965 April. The 973 is either 9th day of April or factory code 973. When I googled 60102 0226 01 some places are listed, including places that list gaskets etc., and I am too lazy to type them here.
Thank you!
Gasket set #495602. Standard ring set 294232. They are available, just need to do some searching.
