Winter Storage: Drain the Fuel or Use Stabilizer?
David Miller
Location
Middle Tennessee
Getting close to putting the mowers up for the winter here in Middle Tennessee.
I've got an older John Deere 345 with the liquid-cooled Kawasaki and a Toro TimeCutter. I used to run the Toro's tank down till it died, and just treat the big tank on the Deere with stabilizer since I didn't feel like draining it.
Neither one ever gave me carb trouble come spring, but who knows if that was my method or just luck.
This year I'm leaning toward filling both tanks and treating them, then running each one for a few minutes per the product directions so the treated gas gets through the fuel system.
I've always wondered whether leaving some air space in the tank makes condensation more likely.
Curious what y'all do with older carbureted engines. Anybody ever had a carb gum up from gas sitting all winter? Wondering if I'm overthinking this.
I've seen videos of fuel treatment (name brands) that gels. If you have the option of draining it and storing it in a dry safe location, I would consider that. If you do decide to store it with fuel, non-ethanol fuel stores and keeps better than ethanol laced fuels.
Hello D.,
I recommend you fill the tanks (as full as possible) with non-ethanol fuel along with a little bit of 2-stroke oil to help keep the carburetors & fuel system protected. Run them for a few minutes and then let them sleep until spring.
In the past I learned not to let fuel tanks on equipment sit empty because the plastic (nylon) gets dry and brittle in cold weather
I also recommend that people to spend the little extra money for quality fuel and quit wasting money on "budget gasoline" and snake oil "stabilizers".
All ethanol blend fuels are destructive when left sitting, especially to a carburetor and soft fuel lines. E-blend fuels also promote rust formation to the inside of steel fuel lines.
If you cannot get non-ethanol fuel in your area, use a good mid-grade fuel along with marine (blue) Stabil mixed in.
Don't use budget "cheap" pump gas, that stuff is the worst you can buy and will breakdown very fast if left sitting in a machine fuel tank or a gas can.
Hello D.,
Thanks, Auto Doc. Appreciate the input.
I've always gone the stabilizer route on my JD 345. I used to run the Toro dry, but neither one has given me carb trouble in the spring. Could be the way I stored them or just luck. This year I'm planning to treat both tanks and run each mower for a few minutes, following the product directions. I haven't tried adding 2-stroke oil, though.
Another very good stabilizer I've been using in customer machines and a couple of mine that sit a little too much is a product called Ethanol Shield. Chickanic has a very good video about this product.
The trouble with any fuel is that if it has air space in the tank or a gas can, condensation forms with temperature transitions. This forms very small droplets of water eventually and collects in the bottom of the fuel tank or gas can.
It is simply the physics of the environment.
